Okay, I have a 1990 CB7. I had to replace the tranny due to reverse being shot. Now, the tranny is in & everything is hooked up but the car won't start! I can hear the starter clicking, but it isn't even trying to turn over. I went and bought a new battery but still no luck. Please gimme some advise!
1990 CB7 will not crank
check your grounds. don't forget the thermostat ground
I always start where it's cheapest and in this case it's the grounds.
What no one has mentioned yet but apart of the same category of grounds is the battery terminals and posts.
Make sure open ends if the positive and grounds aren't too frayed, if so cut and trim them back so all strains are close to even length that is if you can. You might have to extend them.
Moving on.
You should also check your battery for corrosion. If the bastards going to continue spitting out acid the problem will arise again.
There's a battery cleaner kit that comes with bottles of cleaner that foam the acid off and then it has a corrosion resistance. Deluxe kits come with covers you can place underneath your terminals on the post to absorb acid being spat out from seam around the posts.
The posts usually aren't damaged unless it's an old battery or someone didn't secure the battery down.
Ciao
