Well then that must be the issue cause I've been using 20w-50 oil and it's doesn't smoke nor burn oil for a few days.
92 Accord Ex Smoking issue Please Help!
First, go back to 5W30 motor oil, if your 20W50 comment is true. I'm not sure if you were being sarcastic or not.
One person mentioned piston rings for the blue smoke out rear at higher RPM's. Take the person's advice and do a leakdown test.
Valve guide seals if blue smoke upon cold engine start-up.
Spark plug tube seal oil leak fix is in DIY section, that is an issue in itself.
As for fuel leak, I would say do a visual inspection on passenger-side fuel tank area. If it only leaks when near full, then obviously look towards top of tank area, perhaps there is corrosion involved.
No sarcasm I was told to use a thicker oil by a friend. I've already fix the fuel issue. I had a rust whole in a pipe close to the top of the tank. I emptied the tank and had it sand blasted and welded a new piece over the whole and smoothed it out and primed it. I also fixed he sparkplug chambers leak. But I know that when I use 10w40 it smokes so I mix one quart of 20w50 with 3 quarts of 10w40 and it doesn't smoke for a few days. When I changed my oil last it was really thin almost like water
Okay Guys so ive found the issue for my smoke. its the valve stem seals. A few seemed as tho they like to be split open lol. I no longer smoke. boy was i glad i found it too. my spark plugs looked as if the had been sitting in the oil pan. 2 of them were fouled out. Thanks for all the help guys!! Now i can begin on bringing her back to life fully.
