Ive researched and it looks as though the cl and cd are the same chassis but will the rear disk conversion work? got a good deal on some trying to see if they will work. Also i found one thread on this but he did the whole subframe from the back so idk.
Rear disk conversion from a Acura CL
lol mine came with discs from the factory,but all of it will get transferred to my h22 shell eventually. most people opt for the oem swaybar provisions while changing brakes and does not make the process any harder. im not sure but since the cb cd and cl all have the same suspension the subframe should be a bolt in. and its true ive read with certain hodgepodge of parts your wheels do stick out. im sure someone else can chime in that's done it or knows all about itLast edited by illinois_erik; 10-10-2013, 10:40 PM.
Originally posted by illinois_erik View Postlol mine came with discs from the factory,but all of it will get transferred to my h22 shell eventually. most people opt for the oem swaybar provisions while changing brakes and does not make the process any harder. im not sure but since the cb cd and cl all have the same suspension the subframe should be a bolt in. and its true ive read with certain hodgepodge of parts your wheels do stick out. im sure someone else can chime in that's done it or knows all about it
Originally posted by ChandlerFihn View PostWhat about just the rear disk conversion. I need a new knuckle for the rear anyways and I was thinking I could convert to disc at the same time.
Also add the RSB from an Acura Vigor. Its 2mm bigger at 16mm vs. 14mm for the CB and bolts right in. I simply reused my EX bushings and enlarged them 2mm so the mounts were the same
its the TL which is also the same as the cb cd cl. That will give you a wider rear end by 15mm per side so a full 30 mm wide rear end. I used the tl rear end with prelude hubs to get the width back too factory. I keep the TL hubs for a possible future widened rear endCB7TUNER.com
Educating each other one car at a time.
Originally posted by cb9love View Postits the TL which is also the same as the cb cd cl that will give you a wider rear end by 15mm per side so a full 30 mm wide rear end i used the tl rear end with prelude hubs to get the width back too factory but keep the TL hubs for a possible future widened rear end
Please use punctuation. It will help everyone understand what you are trying to say.
Originally posted by cb9love View Postits the TL which is also the same as the cb cd cl. That will give you a wider rear end by 15mm per side so a full 30 mm wide rear end. I used the tl rear end with prelude hubs to get the width back too factory. I keep the TL hubs for a possible future widened rear endOriginally posted by mtnbikaah View Postwhat?
Please use punctuation. It will help everyone understand what you are trying to say.Originally posted by cb9love View Postits the TL; which is also the same as the cb cd cl. That will give you a wider rear end by 15mm per side. so a full 30 mm wide rear end. I used the tl rear end with prelude hubs to get the width back too factory. I keep the TL hubs for a possible future widened rear end.
its not punctuation, reading comprehension perhaps? Better sentence construction? as long as a person knows about something and has two fingers to peck it out, thats all that really matters.Last edited by illinois_erik; 10-13-2013, 10:12 AM.
