I got a really good deal on tokico blue's from a buddy of mine and I need to pair them with springs. I'm looking for a roughly ~2 inch drop (very little less or more), and I know that tokico blue's are pretty much just OEM replacements, but this is the best I can do. So while looking for springs, my noob question is what causes the shocks to blow? Is it how low the springs drop your car or is it the spring rates or both? I've referred to the lowering spring compilation thread but I'm not sure which springs to choose from. Do I choose a pair that's closest to stock spring rates? I'm not looking for an amazing ride or anything I just want to be lower and not bounce too much.
What causes shocks to blow?
Shocks are valved to work with a particular height and spring rate. Springs that lower the car beyond the shock's capabilities result in the shock essentially being partially compressed at all times, and often compressing beyond the designed limits. The valving is there to allow a certain amount of fluid or gas through at a certain rate, in order to compress and rebound effectively with the springs. When the spring rate is wrong for the shock, this valving doesn't work as it is supposed to.
Have you ever played with a paddleball? Rubber ball on a rubber string attached to a wooden paddle? When you get the rhythm right, the ball bounces effectively. Get it wrong, and it's fighting itself. Think of the valving/spring rate being kinda like that (a very sketchy description, but it puts it into perspective somewhat.)
you should be okay using those shocks on a 2" drop. Its not the drop that causes them to blow, its the spring rates.
For instance, I just lowered my 4dr. I used Tein springs front and rear. 2.1" drop front and 1.7" rear, the rates are actually softer in the rear by 18% and a little bit firmer in the front by I think 10%.
I'm not using original shocks though, I got some new monroes for the rear, since I found them for 30 bucks/pair and KYB GR2s for the front that were very low mileage.
Nooooo I was saying eBay sleeves will blow your struts. Not advising him to buy them.Originally posted by deevergote View PostIf you don't have the sense to give proper advice, please don't waste anyone's time. I'd hate to hear that someone on here crashed because they took suspension advice from a fool.
Might want to be more specific in your answers then, I thought the same thing Deev thought.Originally posted by heretoaskstuff View PostNooooo I was saying eBay sleeves will blow your struts. Not advising him to buy them.
Three things you NEVER cheap out on, Suspension, Tires, and Brakes.
Not necessarily. As I said in my original response, the height does matter. A shock is designed for a certain amount of piston travel. Tokico HP (blues) will really only withstand a drop of about 1", which is barely noticeable. People have gone lower on them (and on KYB GR2s, and even stock shocks...) and they were "fine"... but they weren't functioning as designed. Often, the rest of the suspension is so worn and crappy, and the driver so unaware of how suspensions actually function, that they don't even notice the mismatch, or even when the shocks have blown!Originally posted by Losiracer2 View Postyou should be okay using those shocks on a 2" drop. Its not the drop that causes them to blow, its the spring rates.
Op, Just make sure you do things right the first time. Dont waste time, money and safety on bad crap.
BB6->http://cb7tuner.com/vbb/showthread.php?t=200445<Summer Lover
BD6->http://cb7tuner.com/vbb/showthread.php?t=194262<Dailey/Future AutoX
Mazda 6s->http://cb7tuner.com/vbb/showthread.php?t=201313<Wifes
CB7->http://cb7tuner.com/vbb/showthread.php?t=189108<Sold
Also too many fatties riding along
C-3PO's MRT USDM yo!
