my car wont start at the turn of the key but it will start when we push it and pop.it.into gear. iIknow its a good battery cause it stays on once it starts what else can it be beside my starter? but I
starting problems
When you have the ignition S/W in start position, what do you hear?
Do you hear a click sound from relay?
Do you hear clicks from solenoid on starter motor, associated with dimming of instrument lights?
Have you checked for starter safety circuit and S/W for proper operations?
While engine is running, alternator supplies electrical power. So, even with weak/bad battery, the car would continue to run.A&P-IA
im having a similar problem is your car cranking?
if not thats what mine is doing. im thinking starter relay but not sure which one it is under dash...does anyone know which relay is the starter relay??
Ride List
1990 Accord dx coupe - my baby (dsm turbo set up in progress)
http://www.cardomain.com/ride/3202853
2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled
newest 2006 mazdaspeed 6
http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
There's the best place to start.Originally posted by oyajicool View PostWhen you have the ignition S/W in start position, what do you hear?
While engine is running, alternator supplies electrical power. So, even with weak/bad battery, the car would continue to run.WWW.JDMCONCEPTS.COM
Keep .It. Simple. Stupid =K.I.S.S
