I think i snapped the splines on my axles last and i was thinking of useing the axles from a 93 prelude. Would they even fit with my h2u5 tranny?
prelude cv axles on a cb7 tranny
The axles are independent from the type of transmission used as long as you are comparing F/H manuals to F/H manuals and F/H automatics to F/H automatics.
If you are running an F/H transmission in a '90-'93 Accord you will ONLY use '90-'93 Accord axles.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
If you have some prelude axles laying around and your kinda hard up for cash to spend on new/reman axles you might be able to use the prelude axle parts to repair your accord axle.
Everything should be the same except the lenth of the main shaft so as long as thats undamaged should work.
edit: make sure the outer housing you use has an exciter ring on it if your car is equipped with ABS. If no ABS it doesn't matter one way or the other.Last edited by SlimmTex; 11-07-2013, 10:55 PM.
