engine codes 6
    engine codes 6
    hey guy need some help here is my problem I had to open my engine cause one of my valve broke everything was find until I turn my car on when the check engine come on so we check it gave me 6 short blink need to know how to fix this also my timing might be off a bit will fix this on Friday I have a 90 accord ex any help would do thank
    What?
    92ex CB7<-SOLD 93ex CB9shiftingshift73C10
      I have a code 6 which is the cooling temp sensor replace the sensor but still had the check engine light try to reset but nothing
        also car is running and run great just the check engine light is killing me right now
          Which sensor did you change?
            the one under the distributor cap also the one at the end of the cooling hoes or to the right of the distributor cap
              i got the same problem
