spark issue please help!
    okay so i get the head back together and bolted up to spec. get the timing set. and nothing. it just turns like it wants to start but thats it. i had no spark coming from then igniter to the distributer. so i replaced them both. and still doesnt start any ideas as to what it could be?
    Fuel + Air + Spark = Combustion
    If youve already made sure that spark isnt the issue, then I'd look check fuel delivery and vacuum and lines
    Wrecked, Revived, and still Rollin'
    Check out my MRT!
    The most unique "modification" these days is a full restoration. Take a 20+ year old Honda and make it look brand new... and it'll be more impressive than the guy with the stock-block turbo and plastidipped steelies.
      Have you tested or replaced the ignition coil?
      How about your battery connections... are they clean and tight? I've encountered dirty battery connections that supplied enough power to turn the engine, but not enough to start it.
        Check all of your grounds too. The little one attached to the thermostat had me stumped for a month until I found out it was just loose.
          I have fuel and air. the spark still isnt going to the new coil. also my battery and terminals are brand new. I might have to check that ground by the thermostat thats right below my external coil. so that could be bad. could it be my main relay? i mean if the coil isnt getting spark then neither is the distributer. so what send the signal to the coil?
            The main relay controls the fuel pump.
              Okay well i wasnt sure, i was told to check that. I no that the coil isnt getting spark tho. so its got to be something electrical maybe.
