My driverside window is broken. When i hit the switch down or up it makes a constant buzzing as long as im holding the switch down or up. Im not familiar with windows at all. I know theyre a pain to work on cause of lack of space and that keeps me away from them. But the driverside is important for drive thrus and tolls also i did an ac delete so imma need it this summer forsure. The windows not a total loss right now, if i hold the switch down and push down on the window itself itll go almost all the way down same thing to pull it up. Anyone have any clue what could be malfunctioning in my window. Any feedbacks greatly appreciated. Thanks
Driverside power window problem
Sounds like the motor for that window died. Forcing the window down probably isn't helping as well.
I've never replaced the motor, but I hung out on the couch once while a friend replaced one in his truck and it didn't take long.
RIP my last two CB7s.
New rides:
'82 Volvo 245 drift project
'87 Volvo 244 daily
Born2DieApparel.com
had to replace my regulator 3 days ago. easy scale 1.7/10.
a screw in the exit handle.
undo the exit handle rod and wire clip(if u have power locks).
a screw in the bottom left above door light(might have a cap).
a screw in the entry handle.
a small plug on top right, pops out.
get a butter knife or a solid this piece of plastic,
jam it in between the door and pop that door panel off.
undo the wire clips, should be 5 total w/ the exit handle(if u have power locks).
only need a 10mm socket or wrench if no socket but harder.
2 bolts on the window attached to the regulator slide.
6 bolts for the regulator itself.
inspect glass slides and clean out debris if any.
My 92 EX 5 door driver window worked much like yours. I purchased a plastic gear from ebay for $12.00 delivered and new gear fit and worked perfect. I also put in new motor brushes while I had it apart and cleaned up the channel for less friction. Helps to pay attention when taking it apart.
