brake master cylinder
    so i just did a rear disk swap and a legend swap with lude rotors up front. one concern im having is the i disconnected all the brake lines and they were draining into a bottle for about 4 months while i was gathering parts.
    when i went to put fluid back in the master cylinder, they was barely any fluid left (duh) and i just bled the whole system out .
    my concern is that someone had told me that almost draining my master cylinder means that i have to replace it. is this true?
    You should probably take it off and bench-bleed it. You may continually have air in it by bleeding it on the car once it has been completely drained.
      Damn alright. Was hoping that if I bled the brakes like normally than that would solve my problem
