my check engine light was on so I went and got a computer scanner to read it. I got a p0500 code saying vehicle speed sensor a. I went to find out how much the speed sensor would cost and it was about $90 so I didn't get it yet because I spent the last of my money on the scanner. ill have to wait to get the sensor but do you think the sensor would be the only reason that my vtec doesn't seem to be engaging. are there other common reasons why the vtec wouldn't engage on an h22a?
Vtec doesnt seem to be engaging
Ok well I just got this car and I think the person before me really messed up the electrical. The dash lights dont work, the vss isnt working, and the alternator isnt working even though its a good alternator. Also randomly it sounds like theres a cell phone on vibrate getting a txt message inside my engine bay. I think all these problems are linked together but idk how to really know what to chevk for.
I fixed it. basically the guy who had the car before me just screwed up the wiring something horrible. I found the line going from the alternator to the fuse box cut. I took another line and linked it to the fuse box and then I started getting higher voltage from the battery while the car was on. it also made it so vtec would engage even though my check engine light is on with a p0500(vehicle speed sensor). I thought might be keeping from hitting vtec but it wasn't. I still have to figure out why the dash lights wont come on. I looked through the fuses and didn't find anything so ill have to keep digging for the answer
Ok.
Please clarify a few things:
- What year is it (assuming its 96 to present considering you posted OBD II codes)
- Motor type? SOHC with VTEC or DOHC VTEC
- Which model?Henry R
Koni/Neuspeed
1992 Accord LX R.I.P
1993 Accord EX OG since 'o3
Legend FSM
I have a 2000 prelude with a jdm swap from 1997. Its has red top but I don think its from the preludes. I think the motor says p13 hp-1 on it but I dont remember. the car has been faster since fixing the alternator problem probably due to better ignition but I don't think im hitting vtec. im probably just going to buy a new vss and see if that works. Any suggestions for getting the dash lights to work?
