So this is a pretty old thread but I figured I'd just toss this in here. Finally got around to changing out my clutch throwout bearing. I haven't touched anything to do with vacuum lines aside from smoking it to find not one single leak... not one single leak at all. When I drove the car to work, the whistle was still there. Changed the bearing, drove home, the whistle is gone completely. Been driving it for roughly 3 weeks since replacing the bearing...whistle still not present. The whistle sound was coming from my throwout bearing 100% all day.
Anyone that has any knowledge about mechanics knows that a very slight polished metal to polished metal contact can in FACT cause a whistle sound. I've personally run into it before and will certainly run into it again.
Also the whistle can be pinpointed on a lift without taking anything apart. This is done by putting the car on a lift, having someone sit in the car with it on in gear, neutral, in gear with clutch in, in neutral with clutch in, out etc. Then another person underneath the car(me) holds a mechanics stethascope(basic dr.s stethascope but with a point on the end if you don't know) on different spots around the trans housing while the person in the car accelerates slowly, or pushes the clutch in in gear, out of gear etc. to create the sound. If the sound gets louder the closer you get to where the bearing would be then that indicates it's coming from the bearing..... It's really not a hard thing to do at all... it's kinda basic mechanics honestly... and anyone that doesn't know that a whistle sound isn't 100% a vac leak....well shouldn't be working on cars in the first place....
So yes, the whistle sound that you are experiencing can most certainly be caused by your clutch throwout bearing. Again...OP I hope this helps if you're problem has not already been solved.
