I'm looking to remove the plastic around the steering wheel.
    I've searched this forum up and down and cannot find any threads pertaining to removing the plastic around the steering wheel. I am replacing my ignition switch and need to be able to have access to the area.
    The plastic column covers? They remove with a Phillips screwdriver. Did you even look at it before you asked the question?
      yeah I did and managed to pull a couple of the clips loose but there seems to be a portion on top closest to the steering wheel that is attached more sturdy and I'd rather double check that what I'm doing is correct rather than just continuing forwards and breaking the plastic cover needlessly.
        There are more screws than you've removed, then.
          4 screws I believe.. On the bottom of the column cover, 2 towards the rear(dash) and 2 towards the steering wheel.
          Project:Black Skittle
          AOM->April 2014
          MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
            One in the middle too I think
            YouTube Clicky!!
              Thank you. I realized this yesterday as I looked again with a flashlight, those buggers are deeper so I didn't see them.
                There are also two built in plastic clips. You have to push the covers in slightly to disconnect them after you remove the 4 screws.
                93 SE Coupe
