Heater stopped working HELP
    Hey all, few days ago, I parked at a store for 5 minutes came out and there's no air coming from the fan. Fan motor doesn't turn on at all, checked the fuse no luck, what should I check ? I'm opening the dash to check to see if the wire came lose, if not that what else could it be? If it's the fan motor itself how much is a replacement. Moreover the heater was quite weak before this, thermostat replacement needed or? Thanks guys get back to me !
    Sounds like the blower motor is not working. First check to see if it will come on when the fan speed is on high. If it does it is the blower motor resistor. If not it's the blower motor itself I would get one from the j/y. Just pull it from the lowest mileage cb available. I just changed mine midsummer last year. Let us know if you have any questions. As far as your heat being weak before this happened what do you mean, low air speed or cold temps?
    ......father in law has it back again. Time to shine
      Hit the blower fan from under the dash. See if it starts working.
      Long time listener, first time caller.
      1993 Accord LX- Sold (05/2007)
      1992 Accord EX- Totalled (06/2014)
      1996 Accord Wagon EX (Current ride/daily)
      1995 Accord Wagon EX (Beater)
      http://www.hondasociety.com/board/sh...d.php?t=156176
        Yeah that didn't work, I'm just gunna check the wires tonight if not wires I'll do that. And the pressure wasn't the worst but wasn't the best. Mainly temperature was terrible
