Just finished putting new gaskets and seals and piston rings. Now I turn car on an it creeps up to overheating. I put new thermostat and still overheating. Took thermostat back out and just replaced hose to see if I had flow of coolant. I have flow but still overheating. Coolant fans don't turn on. What could be problem?
Overheating
I'm having this problem now. Check your ECT sensors as well as your harness.
Edit: Check your coolant levelLast edited by sonikaccord; 04-07-2014, 09:49 AM.
Was the car overheating before the overhaul?
Check that your cooling system is building pressure i.e warm it up and squeeze the top and bottom radiator hoses (careful not to burn yourself) Check the radiator isnt gunked up, definately figure out why the cooling fans arent working and get that sorted, check radiator cap (or just use a new one to be sure), check how to bleed the cooling system if you dont know already, thats the eaisest stuff to do. failing that perhaps have a look at the water pump... but thats a bit more involved
Yes car was overheating. Guy I bought it from said that's why he parked it. He said needed head gasket so I re did almost all gaskets and seals.Originally posted by NTYPE View PostWas the car overheating before the overhaul?
Any progress>?
I have had experiences (more than once, on other cars) where the radiator has been gunked up, you can run the hose through it and water comes out the bottom so you think that its flowing ok but in actual fact the water is just running straight down only a couple of galleries and the rest of the unit is clogged.
What temp reading were you getting off of the gun?South Texas M_thaf_cka, that's where I stay!
Check out my Frost White CB
http://www.cb7tuner.com/vbb/showthre...ight=SpdJnky93
