Im having some problem with my daily driver. Its a 92 lx sedan 5 speed. For some reason it has no power down low at all. When it comes up to about 3500 rpm the sound changes and it will fly. Its got new plugs, wires ,cap and rotor button. New fuel filter air filter fuel injectors pcv valve and new timing belt. If you take off easy it seems like its dad on its feet and it jerks at about 1500 rpms like you stomp on the gas when i havent pushed ot down any farther. It hasnt always been like this eather. I use to pull up a hill in 5th gear with now problem now i have to how shift all the time.
No power untill 3500 rpm?
Originally posted by F22A1forlife View PostWell i changed out my cam and did a new timing belt and lower tube seals while i was at it. Car runs much better now. I just took the cam from my old a1 motor and its all good now.
I dont want to start a new thread, and I have the same problem. I know these dont have a ton of power, but my teg wasnt this gutless down low. It really seems to struggle getting going until about 2500rpm. Anything under 2k in a higher gear and there is basically no power to accelerate. I had a 93 civic with a d motor and it was pretty week. But even it wasnt this bad.
I have heard advancing timing in my truck and it helps low end power a bit, then reading it in this thread made me wonder if I could this too? And by how much is ok and safe? I just bought the car so im going to clean the maf sensor with brake cleaner this weekend and check the air filter. Ill post a thread about the car, hopefully tomorrow.Last edited by anavrin351; 04-18-2014, 11:50 PM.
Originally posted by anavrin351 View PostI dont want to start a new thread, and I have the same problem. I know these dont have a ton of power, but my teg wasnt this gutless down low. It really seems to struggle getting going until about 2500rpm. Anything under 2k in a higher gear and there is basically no power to accelerate. I had a 93 civic with a d motor and it was pretty week. But even it wasnt this bad.
Timing sounds like the problem but in my case my cam had been change when someone broke the bolt out in the old one and the cam they put in was worn out. try advancing your ignition timing on the distributor. To that loosen the 3 bolts on the distributor and turn it toward the firewall. It helped mine alot. Let me know how its doing. Keep us posted bro.
