AC issue
    AC issue
    Hey everybody. Been a long time since I've been here. Couldn't remember my old password.
    Well, it's starting to get hot outside, and I'm having AC issues; Wanted to see if you guys/girls could help.
    I went and got some freon at Autozone. Put some freon in the lines, and I could feel the cold air in the cabin. Two hours later there is no more cold air.
    I've replaced the AC lines.
    Things I have noticed:
    -When I turn on the AC my car starts to idle pretty rough
    -I turned off my car while the AC compressor was kicked on, and I then heard a sizzling noise come from the AC comp.
    Any ideas on what the issue could be?
    Thank for the help!
    Compressor has leaked out all of its oil? If so then you will need a new/used AC compressor I would assume new/used ac compressor is in order from the sounds you are describing... did you try ac stuff after or before you added Freon?
    " Insert funny quote here "
      I don't see that you pulled the system into a vacuum. If not then you wont have a good start.
      did you use AC gauges? What did the high side do, was it fluctuating?
      Retro!
      Hater
        I'm picking up a used compressor when I get some free time. Work has me consumed.
        I can already tell you know more than me, lol.
        Why is a vacuum needed?
        All I did was change the AC lines, and then tried the 134A again, and it's cold for a couple of hours, and then gets warm again.
          How much Freon did you put in? When you do conversions your not supposed to max it out, I forgot the amount but I think its like 85% compared to r12.
          The reason why you vacuum it is to remove the moisture in the system. Moisture is something that can corrode the system internally. Im amazed it blew cold for a few hours. But you indeed need to check the system with a set of gauges to ensure that the compressor is working correctly and that the pressures are not going through the roof (indicating an issue)
          You can have a leak as well. Best thing to do if you don't have the right tools is take it to the shop they will evac, vacuum, and refill the system and re-check for leaks. I do it all the time myself, but sometimes just having the machine is much easier and no guessing work.
          Retro!
          Hater
            I have a feeling your high pressure relief valve on the bottom of the compressor has a major leak.
            That's how I lost all my R12 in my Original Hadsys compressor that was working flawlessly prior to this.
            I think it would've still worked after replacing the valve, but I didn't want to take a chance and spend 80 dollars in R12, since it probably ran with no oil for a bit when it all dumped out. I replaced the compressor since it had 220k on it.
            The pressure relief valve is a brass valve at the bottom of the compressor, you could probably find one in the JY.
            Just remove it from the donor compressor and blow through it, if you can, that means its bad.
