Adding iabs to pt3 ecu?
    Ok i have been reading on pt tuners and pgmfi and want to know if adding iabs will be a benefit to my pt3 ecu. The reason for my concern is if you canot alter fuel/air maps how would iabs make a difference? And if it is possible then why cant we tune a pt3 like civic ecus? And i tried to post in the ecu section but i cant.
    Please read the rules to see why you can't post in the ECU section.
    PTtuner is making an effort to make the PT ECUs tunable. They're not commonly modified ECUs, and the programming varies from common Civic/Integra ECUs that are currently supported by tuning software. That's why we use Civic ECUs instead of tuning our PT ECUs.
    As for adding IAB controls... there would be no point to it without being able to adjust the fuel curve. It's far easier to simply run a PT6 with the F22A6 intake manifold with IAB, and the F22A6 camshaft (for which the PT6 is tuned.)
    I'm sure adding IAB control to the PT3 is possible... but it's something you'd only want to do for the experience of doing it. There are much better ways of accomplishing it otherwise.
      Ok thank you. I saw the kit on pt tuner for like 2.50 i think i was wondering how it would benefit. Thank you for clearing it up for me
