' 92 Steering column in '90 EX CB7
    So, as the original steering column that came with my car was thrashed and electrically sabotaged by multiple hot wiring attempts, I decided to use my spare '92 column from a Coupe. Everything fits like a glove, although the steering wheel sits at an almost 90 degree angle when driving straight and pulls hard to the right.
    Is there any way to correct this?
    Sorry if there isn't enough information. If you need more, tell me.
    Besides the angle of the wheel, everything works perfect.
    im not sure what you mean by that...
    can you post a picture by chance?
      Did you make sure everything was aligned during disassembly and reinstall? the steering rack needs to be centered before and during removal, then the column re-installed in its "12 oclock" position, and then the steering wheel should go on straight after that.
