Well guys in new to the Honda scene as far as performance and swaps. So i purchased a 1990 cb7 and was forced to swap a new motor because the old f22a4 went bad. The motor is in the car and wiring is done but when i triedto start the vehicle it wouldn't start. Chuckle for a.second but that was it. All of the grounds are attached. I'm getting fuel because the jdm injectors were clogged.so iaam forced to use the f22a4 injectors. The o need lyricsway I can get the motor to rrun for longer that 2-3 seconds is to unplug the iacv and intake air temp sensors and switch those connectors. I have added a connection to the map. Sensor so that I can use the h22 one and 8 have a Mitchell book with the wiring diagram with colors. When the motor is running for those 2-3 seconds the idle jumps to 2000-3000 then back to like 1500, and at the same time I am trying to barely crack the throttle and this automatically kills the motor. What have idone wrong. Can ssomeone please explain and help me.
My H22 swap problem child
You've picked a great platform to start with if you're new to Honda, good job!
So let's think about this before you start shooting in the dark.
Car starts, then dies.
Runs for a bit unless the IACV and IAT wires are switched.
Dies when throttle is opened.
So it sounds like a wiring problem still. Blocking off the egr is a band-aid thing, unless you just want to block it.
TPS wiring good and adjusted?
There is another wiring diagram in the Technical section of the forum.
The H22 fuel injectors deliver 340 cc/min.
The F22 fuel injectors deliver 240 cc/min.
The H22 ECU is programmed for the H22 fuel injectors. Which means he's trying to start up with about a 20:1 air/fuel ratio. With a cold engine. There is no way this thing is going to run.
Might try the F22 ECU.
OK the ecu is stock for a f22a4 along with the injectors for the same motor because the injectors that came with the jdm h22 were clogged. So if i have a friend that is bringing me a p28 that's been sockets but needs a chip with a base map where can i get one?Last edited by clm5519; 07-15-2014, 08:17 PM.
