Hello all 1990 honda accord ex 5spd jdm f22a swap on a pt6
My fuse 2(pgm fi, eld) on the under dash fuse box keeps blowing with ignition in on ll. Was driving to work in the morning and car cut off in gear. Tried to start it back up and no go. Has a solid cel even when jumping the blue connector. No recent work has been done in 6-8 months other then exhaust and suspension. Nothing electrical
-replaced main relay
-removed all fuses not required to start and run the car
- I've tried replacing the ecu with 3 extra ones I have and still blows fuse
-fuse still blows with main relay unplugged
-replaced under hood fuse box
-fuse blows only when connecting white connector to under hood fuse box. The second to last plug on the relay side of the fuse box.
-cruise control switch gives power to ignition like it's in the on ll position. Before the fuse started blowing I had an issue with car staying running without keys. Found out cruise control button could turn the ignition on and off. Never figured this out
Any suggestions on where to look next for the short are greatly appreciated
