Car almost stalls
    Car almost stalls
    Ok so when i try to take off from a dead stop in 1st and the car totally bogs,almost stalling. It only does this when you take off from a dead stop. Im thinking and freaking out about it thinking its the clutch but it says online something about the fuel filter which i think i need to change. Any ideas? All help is appreciated!😊
    Is your check engine light on?
      Nope no check engine light only thing that ever comes on is the brake light. And that is pretty randomly, even tho its a full reservoir
        When was your last tune up? I'd check the spark plugs for oil first if you can. Also, how is your idle is it low? Maybe raising the idle up a bit could help.
          The valve cover gasket and spark plug o rings need done and it idles when you have been driving for awhile at 200-400 rpms and how do you raise the idle?
            Does this symptom happen only upon cold start up in the morning (all air temps) or even when the car is warmed up? Obviously there are a hundred things is could be but it helps to know when it is occurring. I had this issue upon cold starts occasionally. Are you sure your clutch pedal travel is set properly? How much time are you willing to invest to fix it? It could take a long time to figure it out.
            I would do a full tune up - and - check your oil pressure, engine compression, fuel pressure, coolant pressure, battery, alternator, check all vacuum lines for leaks, bleed the coolant, set ignition timing, set base idle, clean out all passages in the intake manifold and throttle body, make sure your throttle cable is not too tight, check resistance on all fuel, air, coolant related sensors, check O2 sensor, pull all your injectors, clean and rebuild them, clean EGR passages and EGR valve, clean IACV, FITV and air boost valve.
            My recommendation is to start with the bolded items and get a service manual.
              there is an idle screw at the front of the intake plenum to raise the idle, near the air intake tubing.
              Procrastination is a THIEF of time!!
              MY MRT
              http://www.cb7tuner.com/vbb/showthread.php?t=203992
              My First CB7
              http://www.cardomain.com/ride/705233/1990-honda-accord/
                A fresh tune up would be a good idea. Plugs wires cap and rotor. Id also ohm test your coil.
                  Thanks guys i think the fuel filter helped a lot but it still idles really low. I guess ill just adjust the idle and see what happens putting axles on today wish me luck 😊
