h22a pulley
    h22a pulley
    Will this chip on the crankshaft pulley cause any problems? I dont wanna purchase a new one if i dont have to.
    The only problem I see it causing is possibly tearing up your timing belt which could result in messing up your engine's timing. If you have a timing belt you should test fit it on the pulley and if the belt sits below the chip you could still use it. However, you should know that there's a possible chance that chip could chew your belt up when it's in rotation. If you're looking for peace of mind, change the pulley.
      That's the power steering portion of the pulley. I have been running mine with something like that for about a year. Not quite that bad.
      It will probably eat through your power steering belt some. Mine is a little worn on the outside where the chunk is missing.
      steve
        Oops, you're absolutely right Stoner51. I didn't pay much attention to the surroundings just to the pulley itself. So JAGcb7 disregard what I said about your timing belt, but like Stoner51 said nothing bad just your power steering belt could be chewed up a bit over time.
          Maybe smoothing out the chip to get rid of any sharpness will help prevent any damage to the belt. Will the chip affect the balance of the pulley. i know its a small chip but still a concern.
            Yeah you could smooth it out a bit if you want to, but I doubt that chip will affect the balance of the pulley.
              Thanks, I appreciate the help.
