Hi all,
So I've been having a fantastic time trying to run down some of the issues with my cb.
It is swapped with the h22a4 motor.
Originally, hmotorsonline had shipped the motor with an ECU that was not a p13. This was a while ago and I cannot remember what the ECU number was now. At the time, it ran the car just fine it just wouldnt hit VTEC despite being wired for it properly. I took it to a performance shop, and had them place an h22 base map on a p05 ECU. This ran the car great with VTEC and no CEL's.
A little while after I began having problems with the fuel relay within the main relay not clicking like it should, and narrowed it down to an ECU issue.
The base mapped p05 has since been replaced with a p13 ECU. The issue Im having right now is the motor is only running on two cylinders. When trying to track down the issue, I have verified spark and fuel to the rail. When I was making sure the injectors were giving me proper resistance, I realized they are high impedance injectors.
My question is this - since these are high impedance injectors, shouldnt I be bypassing the resistor box? Could this be my issue right now? At this point Im kind of confused at what else it could be.
Thanks for any input!
