Hi I was wondering what is a good turbo kit for f22a6 and where I can get one.
good turbo kit
I would suggest A LOT of research. I'm in the middle of building an engine right now for 275whp for a friend as well as being in the early stages of a 350whp build for my Accord. Despite what anyone else tells you, throwing a "turbo kit" on your CB will not last. It HAS to be rebuilt with at least forged pistons. Period.
If you want a "kit" which you don't have to put together, just buy it and it has everything you need as for the FI system then here you go:
http://www.treadstoneperformance.com...+H23+Turbo+Kit
They used to have an Accord kit listed but this one is the same thing. They might be working on their website. Here is an Accord one but the F22A is no longer listed. And it also says H23 which isn't correct but they have the right kit. They would just need to be contacted prior to purchasing to ensure you get an even port turbo manifold.
http://www.treadstoneperformance.com...+F22B+and+F23A
If that amount is a lot of money is too much for you then you might want to buy another car or find something else out. $3800 is about what it costs to turbo a CB7 and to some that's cutting some corners. Just don't expect 500whp on a forged piston F22A with nothing else.
You need to upgrade the fuel system. Pump and injectors. And have a way to tune it. You need gauges. Wideband, boost at least. You need an upgraded clutch. Exedy stage 1 at least. No eBay crap.Last edited by H311RA151N; 09-27-2014, 02:52 AM.
