I recently purchased this Accord. It has a few problems. To begin the speedometer only works when the lights are off. The drivers side front turn signal didn't work until I made a new ground for it. While fixing that I discovered damage in that corner. The wipers don't want to turn off easily, and turning on the lights can turn on the wipers. Any help as far as where to start would be greatly appreciated. Also I forgot to mention the left turn signal causes the speedometer to bounce gradually down to zero as it's left on, and the cruise control doesn't work.
Electrical issues galore.
I have a dmm I used to make sure the starter was getting a signal to the relay before I replaced it. I'm a novice when it comes to electrical stuff. Also the car has been in an accident and the motor and interior has been replaced at some point, I think. The car is an 1990 ex according to vin, but lacks automatic shoulder belts and has an air bag in the steering wheel as well as a block stamped with f22a1. I am questioning the person skills who did everything or whether I could get it all working as it should.
you should just start fresh with an uncut main wire harness from a JY car. That would honestly take hours and hours of time to troubleshoot, when you can just get one from a JY car that's plug and play.
member's ride thread
91 Accord SE 176k
I was thinking the same thing. I don't even know if that would work. Nothing was left unmolested. The car doesn't have a sunroof. Being an ex it should right? I picked up the car cheap, but I'm beginning to find out why. I am almost considering finding another Honda.Originally posted by Losiracer2 View Postyou should just start fresh with an uncut main wire harness from a JY car. That would honestly take hours and hours of time to troubleshoot, when you can just get one from a JY car that's plug and play.
I would get the engine and dash harness since your speedometer and wipers are affected. But if you can get all three from a clean untouched CB7, that would be ideal.Originally posted by bohnkekong View PostI was looking at car-part and they list three different harnesses; engine, dash, and body. Idk if I would need just one or all three of them or what. My guess would be just the body wiring harness.
Hell you might want to purchase a wrecked from the back CB7 that's totalled. Sometimes you can get those for 200 bucks, would certainly be cheaper than buying those harnesses individually from a JY.
I bought an entire CB7 with a blown headgasket for 300 and sold it for 2800 after investing a total of 1500.
91 Accord SE 176k
Originally posted by Losiracer2 View PostI would get the engine and dash harness since your speedometer and wipers are affected. But if you can get all three from a clean untouched CB7, that would be ideal.
Thanks for your advice. I'm going to do a little phone work and see what I can find. I like the idea of getting a whole car. There are a few other pieces I could use I'm sure.
