i am doing a swap and need help with the H22a! i bought a OBD1 head and the cams and block with a slightly melted piston.. plan on honing it out. im doing a high compression build, im going skunk2 valves/spring. nappon pistons.
my questions are what size of pistons do i use? i seen somewhere that the blocks that have "BBBB" are 87mm? does that mean i need the 87.25mm so it fits after its honed?
what size of injectors do i use?
can the F22 fly wheel, T bracket, intake manifold be used?
thanks in advance
thanks in advance
