That is the master and slave for you're clutch are bad mine did that too changed them bleed them and its good to go it took me for ever to bleed them by hand but that's what that is
Transmission shifting problem
Did you not see that he replaced both of them already?
It's a bleeding issue. That's all it is. My car was down for months (ok, years, because it's a project at this point...) because of a clutch hydraulic bleeding issue. Trust me... it's just a bleeding issue. Try prying on the fork where it meets the slave. That's what finally worked for me.
Just as a follow up on bleeding these clutches. I've had many problems doing this but the last time, I did it in under 5 minutes, by myself. I did this by pressing in the clutch like normal with the slave cylinder open, then squeezed all the rest of the travel out of the slave cylinder by hand. Did this about 6 times and clutch was perfect! I know this doesn't help the the topic at hand but might help others bleed their clutch much easier.
