Hi all,
I am relatively new here to the forum I made an account a while back but I have never posted anything up until now, and I was hoping you guys could help me out. I have a 1991 Accord Sedan LX that I replaced the clutch on. I started the job about 9 or 10 months ago but ran into some problems and school came around so I let it sit the whole time while I was away and only worked on it on breaks or whenever I was back home. Ran great before I let it sit. Spring break came around and I got the tranny back on to getting everything fitted up with some help. Right after going to try and turn the car on the clutch pedal didn't have any pressure so I spent a day bleeding it and eventually got pressure in it. Now I go to crank it and it just cranks but does not start. It also gives the most weirdest cranking sound. The battery was brand new 10 months ago and still has some juice because it cranks the car pretty strongly. I replaced the main relay about a year ago and my guess is that it should still be good. I had my cousin crank the car while I stuck a screw driver in the spark plug wires and got zapped from all four wires so I am assuming I have spark. I undid the gas cap and I heard all this pressure be released and I put fresh gas in. I cranked for a couple more times and still nothing so I loosed up the bolt that relieves pressure from the fuel rail and nothing happened. No gas came out and no apparent pressure was released.
I am just wondering if something with the injectors must have gotten clogged from the time it was sitting or why is it that I am not getting any pressure. I got an injector cleaning about two years ago. I also am not hearing the 'fuel priming' after turning the key.
Just wondering what I should do from here.
Thank you
-Antonio
Thank you
-Antonio
