I was unaware I was being a smartass. Sorry.
manual cluster
Tuning software like Hondata and Neptune can figure out which gear you're in based on the rpm and vehicle speed sensor input.
It may be possible to get that information from the ECU and display it somwhere, probably a hassle though.
But you could (if you knew what you were doing) Design a stand-alone circuit which takes the rpm and vehicle speed signals and does some math processing and spits out what gear you're in.. probably a fairly simple project for your average arduino geek. sadly im not.
If you wanted to go old school you could even do the same thing with discreet logic, transistors, shift registers,74XX gates etc etc.
