All plugs are receiving spark and all injectors are receiving sufficient fuel, the distributor is brand new as well as the tps. Using p13 ECU but also we tried my friends chipped p28 ECU from his cb7 and still the same thing, codes thast were pulled are for vtec and coolant temp sensor. The spark plugs are brandnew NGK iridiums also. Timing has been flipped 180 and back. We pulled the plugs and they had some black soot on them cleaned them off and still same issue..it turn over it just wont start..PLEASE HELP
H22a will not start! 93 accord lx 5 speed
i should have mentioned that i did have this motor in my 95 prelude before i decided to put it into my accord..both cars ran perfect i just like my cb7 so much more and wanted the power it had from my prelude..thats why im so confused as to why it wont start now..all ground are golden and connectors connected..damnit..could there possibly be a short in the harness? i hope the timing isnt whats off..and if it is i hope the valves arent bent..
Since the engine was running fine before being pulled, I can't imagine there being a cam timing issue unless you replaced the timing belt or had the t belt off and back on for any reason. Otherwise, I would rule out cam timing. Were the plug wires, distributor off during the swap? Is it sputtering/backfiring at all when you try to start it? Did you do any kind of internal/external coil conversion?
when i had the motor in my prelude i had the external coil..in my accord it is also external coild..both motors are obd1..the belt was never taken off nor were any pullys..when i go to start it theres sometimes a little soft pop sound but thats it..i swapped the motor completely intact with trans connected still..this is seriously keeping me awake at night
preludes are fucking amazing dude..but mine was dangerous..pulled to one side really bad when hitting vtec or breaking..and i need 4 door BUT ANYWAYS..figured out the problem guys..dropped the motor took off the pulley covers an valve cover..the timing jumped about 6 teeth..no bent valves though..adjusted timing..and it started up perfect..first try..it was beautiful
Glad to hear you found the problem and there wasn't any harm done.Originally posted by NinetiesBabyCB7 View Postpreludes are fucking amazing dude..but mine was dangerous..pulled to one side really bad when hitting vtec or breaking..and i need 4 door BUT ANYWAYS..figured out the problem guys..dropped the motor took off the pulley covers an valve cover..the timing jumped about 6 teeth..no bent valves though..adjusted timing..and it started up perfect..first try..it was beautiful
Or tie rod, or ball joint, or upper (or lower) CA bushing, or... you get the point. There was a weak link in the suspension system on that side of the vehicle. Comparing CBs to Preludes is apples to oranges, though.Originally posted by deevergote View PostJust so you know the reason the Prelude pulled to one side was very likely due to a blown shock.
