Jdm f23 tubular exhaust manifold on 91 cb???
    Its been a while since i been here.
    been very busy on my 91 lx cb.so,
    Today i come across a much needed oil pan.also came
    Across a tubular style exhaust manifold 4-2-1
    WILL THIS WORK ON AN OEM CB SET-UP?
    if not what is needed for it to work thanks
    Going to snap some pics now.
    I will try from my phone. Like always
    Thanks in advance for all your feed back.
    The following is what ive done since ,
    Resurrecting her. In april2015.
    New: frnt&rear.susp,shocks,2in drop coils,
    Camber kit,tires,oem 7 spoke alloys,alignment, dizzy,alt,batt,
    A.c. retro 134A. T-belt,wtr.pmp.&cover,valve cover,
    & sonar taillights (a.k.a 50:50's).
    It won't work at all unless you:
    1) Swap in an F22B1/2/6 or F23A1/4/5/7 head (or their JDM equivalent)
    2) Swap in one of the aforementioned engines
    3) Reflange the header
    It's a tubular header. They're like $60 brand new on eBay.
      Option #3 wouldn't really even work, since the pipes aren't even in the correct location. If you reflange the header, the pipes would be offset. You'd need to weld elbows in to change the pipe inlet location.
      This is one of those things that could've been answered simply by looking at the parts in question.
      F23 (and all of the other engines Jarrett mentioned)
      F22A
        Thanks for the input, I've already started looking
        For an ebay set up,alot less work and no fab work.
        Just thought id ask since i like to preplan and organize all my projects ahead so as to have everythung on hand. Save time& $$$. And learn
        Something while im at it.
          Be sure you get one with an o2 sensor hole in the correct location.
            You could heat and move the pipes, but I chose not to explain because the overall point I wanted to make was that it wasn't an effective option for a header.
              Ah yes, I hadn't considered that. I wonder how long the average cheapie header would last with such abuse!
                Came Across a Megan racing header with attachments.
                Also this is for a daily driver that just needs a lil more pep. Also have ram air intake and performace muffler.
                Also have cb9 ecu installed.anything else that you all,
                Might recommend to help lively her up
                Ive read and noted the j.y. $500.00 or less list
                And already have whats been available to me.
                Honda parts go very quick here. So always on The
                Lookout for nice parts. Thanks again.
                  Attachments?
                    The f22a4 are OEM tubular is you want a slightly better flow that the restrictive ones you got other than that eBay or DC headers. I happen to have a DC but will require welding a new flange to where it bolts into flex pipe or cat converter. Plus I'm a noon here so can't sell it darn
                      Hey f22 a i feel ya on the noobie thing as i too am
                      Restricted lol .... Im posting some atth. Of my bby and the tube exh. Thanks every 1 .. Orlando Fl
                      Stand up. [URL=http://s781.photobucket.com/user/mytre3eve/media/20150727_091347_zpsbjbcoexp.jpg.html].jpg[/IMG][/URL
                          Not allowing the other pics
                          Im try something different plz 4give
                          Doing this from my phone. Ty.
                            [URL=http://s781.photobucket.com/user/mytre3eve/media/20150816_181415_zps1pwjtjl6.jpg.html][/URL
                              Ok. Finally there they are.
