noise when changing gears?
    i have a 90 lx manual stock with 205,xxx miles i've put 7k on it myself. Car runs and drives good, sometimes a little hard to shift but it has it's days. I plan on getting a new clutch cause i'm not sure when it was last changed. Well my question is when i change my gears here lately i hear a noise kinda like when you put it in reverse. Plan on gettin some honda mtf and changing the fluid, but would like the input of you honda guys cause this is my first honda. oh yea you can only hear it on the passenger side when the windows down.
    Not sure what you mean by the same sound as when putting it into reverse. is it crunching?
    sold! But here's my build thread for those interested.
    http://www.cb7tuner.com/vbb/showthread.php?t=206864
      not really crunching or grinding but like when you change gears on a 10 speed bicycle
        ... I'm sure its fine. If the car is hard to get into gears check your fluid level, bleed the clutch and check for leaks around the master and slave.
          thanks for your help buddy i will check out all of the above
            is it only when changing gears? if you just press the clutch in does it do it? if it does it just when you push clutch in it could be throw out bearing or pressure plate. if its only when changing gears its probably a little low on fluid
              bleed the clutch.. drain the trans fluid.. i run pennzoil synchromesh in all of my cars..
                it's only when i change gears. how many quarts of fluid will it take to change my trans fluid?
                  2 quarts
