i just found out my radiator fan isn't working, my car started to over heat while i was setting behind a wreck. i didn't let it get too too hot it never reach the red it was about a quarter away from it, so i turned the car off until the police let us pass. my question is since my ac doesnt work could i swap out the fan for it to the radiator just until i can get the money to fix it right.
radiator fan went out question about swap
Originally posted by cb7 justin View Posti just found out my radiator fan isn't working, my car started to over heat while i was setting behind a wreck. i didn't let it get too too hot it never reach the red it was about a quarter away from it, so i turned the car off until the police let us pass. my question is since my ac doesnt work could i swap out the fan for it to the radiator just until i can get the money to fix it right.
It might be temperature switch, which turns on fan.
To check if it is switch - turn ignition on and jump temperatures connector, it is two wire connector and it is located on thermostat housing:
http://www.d-series.org/forums/attac...r-img_0699.jpg
Just unplug this connector and jump it, if fan turns on - problem is in the switch.
If it doesn't, you could use your A/C fan, you'll have to extend wires that plugs into your radiator fan and plug that connector into AC fan, connector fits directly.
