Just finishing up my wire tuck\abs removal, and im questioning where this connector goes... cant seem to remember!
Help where does this connect to?
That really looks like the factory foglight harness, those should be the connectors that tie into the engine bay fuse box. I'm assuming those 2 connectors you're holding are entirely separate from the engine harness wiring, the pic angle makes it harder to decipher what's what! You have a harness that pokes out of the firewall in the correct spot (behind charcoal canister or below emissions black box). If those connectors are the end of that harness, then I'm certain it'd be foglight harness. I will also add that 90/91 engine harness has a connector like this but not on 92/93. OP stated 92, which doesn't use the brown booted connector on the engine harness.Last edited by Granite CB7; 10-21-2015, 09:04 PM.
I thought it was the fog light harness, the back side that is inside the firewall has two plugs, one with a single blue wire and a brown connector, and the other is like a 8 pin brown same style that is outside the firewalll. yeah its a 92/93 not 90/91 so no brown connector on the engine harness.....i could snap a pic of the other side.... i was just stumped, i figured maybe AC or ABS or Foglights? I never fully deleted everything until now, so maybe something that was left over
