Clerafication on rebuild for f22b dohc non vtec
    Ok this motor has alot of confusion and I have a f22b dohc in a 93 with bad valves. From research I have found h23 valves will fit. Most people are saying to use f22b sohc headgasket but between that and f22a sohc gasket it looks closer so I will be using it I have a gsr timing belt and f22a intake gasket this is a set in stone plane I already have parts order and will be putting together. I will put my problems up as I go. This might be so if so I apologize in advance
    F22a head gasket will work.
    ~Nick~
      Thanks you have helped my cofidence
        The F22B DOHC is pretty neat head. I did a swap in my 92 EX (F22A6 -> F22B DOHC) where it was just the head (did it just because I wanted to mess with my car). Never had any issues. I'm sure you have figured out that it's pretty close to an H23, not identical but close enough. The head swap alone got me +20hp to the wheels on the dyno (not the "butt" dyno an actual one lol). As far as the head gasket I used was an F22A, literally went online and purchased one for my specific car. Fit like a champ
          The head swap alone shouldn't have given you 20whp. The F22B has 20 crank horsepower more than the F22A6, and a higher compression ratio. It shouldn't have even given you the full 20 crank hp!
          Anyway, Onalimbcb7, do a search for the proper part numbers for the F22B parts. They are readily available overseas. You can cross-reference those numbers with parts available in the US, and anything that's F22B-specific you can order. That would be the best way to go about it.
            What car has the f22 DOHC? Also what are some power gains with it swapped?
              https://en.wikipedia.org/wiki/Honda_F_engine
              (Ignore the F20A specs. They're wrong.)
                tuned on hondata it made 146 who 146tq to the wheels
                  Nice, seems like a fairly simple way to gain 20 whp,
