prelude vti rear brakes into CB?
    Hello. Without unecessary talking:
    I've got 92 Accord EX. It has rear disc brakes. Im going to do 5x114.3 swap (Prelude Vgen VTI front knuckles with hubs and bearings, and prelude Vgen VTI 4ws rear hubs and bearings on accord knuckles)
    The point is: is it possible to swap rear calipers into accord from prelude Vgen VTI 4WS? what i've seen, calipers looks almost the same, the difference is that handbrake cable is differently routed... In accord handbrake cord is above the hubs and others, in prelude this cord is below hubs. Other thing, in lude calipers are on the center side (in "front" of car), in acco - near rear bumper.
    Is it possible to work? how can I secure handbrake cord of tearing off?
    If you can use the whole rear hub, I don't imagine mounting the Prelude brakes with the caliper in front will be an issue.
    As for the emergency brake cable, do you have the Prelude cable? I'm not positive, as I've never attempted a Prelude brake conversion, but I'd think the Prelude cables would work properly on the Accord with the Prelude brakes.
      In case you are not aware, you won't need them to perform the conversion. You can reuse your Accord rear caliper and e-brake as it is as long as the appropriate rotor is used.
      That would be a rear rotor from a:
      '98-'02 Accord V6
      '97-'01 Integra Type R
      '02-'06 RSX
        yea, the thing is my friend is in emergency and he need OEM acco IV calipers. And I have also prelude VTI calipers and I'm thinking about installing them on my own acco in the future if it's possible
        about a cable - prelude and acco cables look the same, the mounts are twin-looking, so am I thinking right that even accord cables should work properly? I think preludes cables could be too short for sedan IVg...
        the "caliper mounts" (sorry, i don't know how to name it :P in Poland we call it "jarzmo" :P ) are the same in prelude and acco, so caliper fit pnp to accord knuckle
        Jarrett,:
        '98-'02 Accord V6
        '02-'06 RSX
        These rotors fit prelude hub, yes? afaik, for itr rotors there's a need of grinding prelude hub, acco V6 rotors should fit without any work on?
          The Accord V6 and Integra Type R rear rotors are the exact same, so I don't know why that would be.
            yes, but my friend swapped preldue bearings and hubs to accord and he used ITR rotors. Prelude hub diameter is a little bit larger than itr rotor and it need some grinding.
            But, my question was about e-brake. Now I thing I know what to do tommorow I'll try fitting this calipers to accordeon
            I hope it will work
