First my dome light wasn't working and i heard that they are connected by the same fuse. So i checked for a fuse (just so happens all my fuses are good) so then i replaced the bulb, now that's working. So I'm wondering why isn't my cigarette lighter working but the backlight it has light up as if its going to work but doesn't. I really need this for my car charger. I don't smoke 🚬's
dome light works, cigarette lighter light up sometimes, but it doesn't work
Does your radio work?
What backlight, specifically, the light surrounding it?
As that has.nothing to do with the port having power.sold! But here's my build thread for those interested.
http://www.cb7tuner.com/vbb/showthread.php?t=206864
Yes. Factory radio worked, i installed an aftermarket radio although that works just fine. And Yes i was referring to that light. I didn't know if it did or not because sometimes its on and sometimes its not.Originally posted by lbus9168 View PostDoes your radio work?
It turns on and off with the lights, if its flickering the issue is due to either a bad bulb or bad ground.
You need to see if the port is getting power. Unplug the connector from th rear and check the power with a multimeter.sold! But here's my build thread for those interested.
Originally posted by lbus9168 View PostIt turns on and off with the lights, if its flickering the issue is due to either a bad bulb or bad ground.
Ok ill give that a shot hopefully on Wednesday on my day off. Thanks in advance
