Battery light comes on if i use the ac periodically or during low rpms under 2.5k... if i rev the car past 4.5k the light will turn off for a bit then eventually turn back on. This all started today, the day after i rinsed the engine down using purple power and a water hose. Could i have messed up the alternator? It was just recently installed in april
Alternator? Loose belt? Voltage regulator?
If you think it's the alternator, turn everything in like the AC, lights, wipers, etc. Check for 13.8+ volts under load. Charged battery should be 12.6v.
Also test how much AC voltage the rectifier is letting through. A small amount is fine, but anything over like .05v might cause problems.
Make sure your terminals and grounds are clean.
Go for a new belt and don't buy a remanufactured alternator from AutoZone get a brand new Bosch from Amazon and you won't have any problems. BTW go with a bando belt never had any problems with them daayco and all that other shit constant squeals and bullshit lol.Last edited by Kev1990; 07-28-2016, 06:23 AM.
