I have a 1990 honda accord 4cylinder, 5speed and a while back I got on here about converting the distributor to external coil. A lot of people recommended just putting the original back in it with the internal coil, so I did.I finally put the distributor in, fired her up and found the temp gauge is not working, the tachometer is not working and when you turn the lights on with the car running. The bell goes off like when you leave your lights on and shut the car off.anymore advice would be much appreciated, thanks anyone
issues with gauges
Did you mess with your wires when you were trying to convert to external coil? It sounds like a wiring issue to me. Look closely at your wires to be sure nothing is damaged. If the car has been sitting for a while, it's possible that mice may have gotten their little teeth into wires somewhere as well.
Trace the wires going to all the components that are malfunctioning. You're bound to find something.
