Dyno prep
    You could always pick up some quality wire of the appropriate gauge and rewire it yourself. Labor intensive, but not terribly difficult... and a good deal cheaper than buying a pre-made harness.
    Or just hit a junkyard and pull a clean CB7 harness. Then add the necessary wires for your engine.
      Is there a write up on any of this? Thanks a BUNCH Deev!!
        Are your map sensor and egr connectors mixed up? I believe they will physically fit but cause issues when swapped around. Double check wire colors and make sure everything is going to where it needs.
        YouTube Clicky!!
          I will double check this and update y'all. Thank You!!
