So I ended up finding out what is causing my CB7 to leak brake fluid and it happens to be the ABS modulator. I know I can do an ABS delete and that'd fix it but I don't have the sources to get that done and stuff. I was wondering if I removed the fuses for the ABS system would that stop the system from taking brake fluid from the brake system, therefore stopping the leak?
ABS modulator cap leaking
The abs reservoir is overflowing. I realized that after posting, my bad. My father suggested the idea that the cap was causing the leak. But as I look around the abs modulator area, I see a whole bunch of brake fluid eating paint damage (my aem intake has it's paint peeling off
). In all honesty, I don't want to delete it, but I've read the DIY for repairing an abs modulator and holy cow, I'd rather tear shit up haha
Do you have your abs light on? Start with that first. If not I would bleed your abs and then brakes. These are easy things to do. Get one of those simple self bleeder units at the auto parts store and I can walk you through bleeding your abs. If your abs light is on I can walk you through reading that too. I've had every dash light on in my car and fixed all of them. These cars can seem complicated sometimes but after 24 yrs there's a diy for just about every problem lol.5 studded & leather clad - Praise The Lowered
~Mark~
The ABS light is on but its only becacuse I removed the fuses to see if that would solve the problem. And I realized just now that I left those fuse back home so I won't be able to get them until the weekend. I appreciate the help. I think I may try bleeding the system first, but I will do that on Friday
Yeah no prob. When you put your fuses back in wait a few miles to see if the abs light comes on. Then we read it to see if you have some problem like "pump over run" which is common but fixable or a sensor out etc. if all is well then I would definitely bleed that abs. Some nasty stuff could spew out of those lines if it hasn't been done in a long time. Mine were awful. The brake lines as well.5 studded & leather clad - Praise The Lowered
~Mark~
