Originally posted by CB7_Saloon
View Post
Fuel Pump Issue?
you should be able to get one from just about any 90's honda, yes the 95 one is the same. you only need to reset timing if you pull the distributor off - sometimes you can get the ICM out while leaving the housing still mounted, but if you have to remove it, mark the alignment of the mounting tabs so you can put it back in the same place. good luck!
