Lack thereof I think is more accurate these days. I've been scouring the interwebs, searching this and other forums, coming up pretty short. I am still in the very beginning stages of coming up with a formula, forged internals will be a must with my goals. I will be installing Darton MID sleeves, part # 400-150 and have had trouble finding pistons I want. Goals for this build will be a mostly street driven 250+ hp (hopefully close to the same torque). E85 will be utillized for this build.
I want 88 mm or larger pistons. Helpful info and suggestions are welcome.
Edit* I know there are some H22 H23 options out there but the compression height of the piston and valve clearances become an issue as I want to use the factory .026 (after crush) MLS head gasket. 1 mm over size valves will be used. A cam somewhere in the neighborhood of jdm_accorns' (mine will not be a mirror image of his but I have not got to the point of picking 1 yet) should give you a rough idea of where I'm wanting to go with this.
No marathon gets easier later. ...
