hey im changing out from auto to manual.... any advise?
conversion
search and read
here are a few links
http://www.cb7tuner.com/vbb/showthread.php?t=204130
http://www.cb7tuner.com/vbb/showthre...=&threadid=588
its really easy just take it one step at a time
No marathon gets easier later. ...
As you will likely find in the links Jacob provided, as well as any number of other threads on the subject, you will need to address the transmission mount and/or bracket. The auto bracket is not the same as the manual bracket, which will result in the entire engine/transmission not sitting correctly. To do it properly, you will need either an aftermarket conversion mount, or you will need to cut out your auto bracket and weld a manual bracket in its place. To my knowledge, the manual bracket is discontinued, so you need a donor/junkyard car to pull one from, if you go that route.
Keep in mind that this forum has existed for 15 years. The information you need is likely here... for any question you may have. Please search a bit before asking. It’s not common for people to be helpful when you haven’t shown any initiative on your own. You’ll find that you’ll get more advice than you could ever hope for as long as you convince people they’re not wasting their time giving it to you.
That being said, I understand that most of our picture links are dead. Not everything is clear without pictures.
