P0107
P0108
MAP Sensor - Basically the more vacuum the lower the voltage reading. So at idle you will likely have your lowest voltage.
O2 Sensor - Probe the signal wire(do not cut). At temperature, and normal conditions, it should read around .45v and fluctuate around there. Give it a good amount of gas, and the voltage should raise to around .8-1v.
Hope this helps, man.
P0108
