I have a 92 Accord LX that has its "power" door lock not working on the driver side. I have to manually lock from the outside door lock. I do hear the actuator motor everytime I manually use the key. The passenger side works fine. Thanks.
Driver-side power door lock does not work
If you hit the lock switch with the door open the driver side door will not lock. This is a safety feature Honda put in to prevent you from locking your keys in the car. To get around this. Simply pull out the interior handle and press the lock button. This will lock the driver side door.
Now if this is not the problem you are talking about then you power actuator is going out.~Nick~
Based upon the responses, I believe it is the power actuator. I am familiar the normal door lock restrictions with the car. I could not find videos on the CB7 actuator, but did find them for 1994-series and up. Anyone know if the 94-series power door actuator is the same design as with the CB7?
