I have my 1992 CB7 Honda Accord sedan that i recently did a complete JDM H22A DOHC VTEC swap with 5spd trans. Everything was included but the ecu and harness. Its done and swapped in but since the ecu is not here i heard that it could temporary run on the stock accord ecu just without the vtec so i did but of course had to modify the dizzy by switching its from OBD2 with internal coil to my F22A6 OBD1 external coil which was running fine and i drove all around just no vtec for 2-3days had A/C on and stereo bumping too drove just fine.
https://youtu.be/i-fVmNVGOIE
Ok, but now today i go to try drive it all of a sudden doin this bogg down and die off issue(as if being starved for gas and/or air)
So now it starts it idles but soon as i turn on an accessory(lights, A/C, stereo,etc.) or just even try revv up engine it immediately bogz then dies off.
Start it up again takes a while but starts idles but thats nothing on at all this time i stomp gas it probly only rev up to 1400rpm then straight boggz down and dies. So again start idles fine this time i try step slowly till floored it intermittently revved boggz revv boggz so I try lift stomp lift stomp to keep it running but constant bogg down as soon i let up just dies off. Cant even move the car itll just die. What might cause this??
My troubleshoot begins:
* so i try PT6, P0A and P12ecu (waiting for P13 & harness to come in mail.) All the same. However it seems the P12 had better results but still same bogg die issue
* I tried 2 different EGR's that do work. Same issue
* tried 3 different resistor boxes. Same
* tried 3 different throttlebodies w/TPS. Same
* tried fuel rail injectors. Same(i started car with fuel rail injectors out to see the sprays all are consistent but thats just at cranking)
*fuel psi is at rail is 38psi
*tried 2 different O2 sensors. same
*checked timing with service plug jumper its on point. Same
*pulled valve cover to double check mechanical timing sync of cams to crank.(incase something eg. Cam off a tooth) all in spec. Same issue
* ECU backup reset each time. Same
*i tried just completely disconnect battery for 24hrs or so. Try again.
Same
*stock air filter & duct is clean no obstruction
* PCV is good and new. Same
What the hell is goin on here it seems almost as if someone sabotage it cause i was just driving fine idled fine a/c on and stereo on three or four days ago now... why all a sudden get this bogg and die issue?? Even attempting various part checks changes still same. Am i missing anything or overlooking something??
>*>>(Please i already know that obd2 obd1 and ecu conflicts if u are a straight only by the honda book guy what comes with what and goes with what. But i changed internals of dizzy from my f22a6 obd1 to the body of obd2 jdm dizzy for H22A using PT3 ecu and it ran ok for few days w/o vtec tho. Casual drivin cruising with accessories on not exceeding more then 4krpm just to be safe. But since this bogg and die issue that suddenly developed overnight while troubleshotting i have the P12 ecu on it for now. As i await yet for the actual propper P13 ecu with vtec harness to come.
I'm worried that even with my P13 ecu and vtec harness comes in tomorrow that i change it that this issue still remains. Ive researched the ecu pins differences they use the same pinouts so nothing is crossed, bout the only difference is colors used of wires between years and the addition of vtec/knock sensor. But still despite colors pins at ecu is same.
Sorry been away for a min but i solved all the iissues of running the engine. It came down to the very specific vacuum hose locations to manifold i basically had to compare prelude chassis vacuum diagrams with my accord chassis vacuum diagrams and reference with specific manifold i using and added issue was also base gasket of egr. So now vacuum hose arranged proper to their specific locations starts runs drives vtec and all. Its all good now and driveable, just a whole nother issue i tryina overcome is this motor runs so extremely hot! So much so i feel an extra radiator and fan setup maybe needed. I cant even run a/c long or drive on a already hot day...
i dunno wussup with this new website update wont lemme repost or reply my own threads. Etc. I been long time member i have posted and subscribed as well as started threads posts discussions etc.
Same
