Delta cams???
    Delta cams???
    So I have been doing some reading up on doing a regrind of my camshaft. My only problems with it that hopefully someone here can help me with are as follows.
    1. Do I need to upgrade anything else if I do this job?
    2. Will reliability/driveability of the car diminish
    3. What kind of power gains can be expected by just replacing the cam
    4. Is it better to go with an a1 cam or an a6?
    I really want to do it if the power gains will be worth it. Between the cam and switching to an a6 or h23 intake /exhaust manifold, I should be able to see some big gains?
    Sorry for not searching if this has been covered but I am sick as shit, and honestly I just didnt have the patience.
    No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
    I bet I'm sicker right now.
    1. Depends on how aggressive. For the normal 272 delta grind, nothing else HAS to be upgraded.
    2. No. It will require fine tuning though
    3. Depends on your other mods. Just cam, you'll see around 10whp+
    4.a6 cam
    Shift_BOOST
    BOOM!
      I am planning on going "normal" 272
      I have some other basic bolt ons
      I will have to redo the valve lash specs?
      My other thought was finding an f22b dohc and having both cams reground to the 272 spec.
      That should bump that motor quite a bit without me worrying of blowing a turbo or some nightmare like that.
        Is it a good idea to get some sort of ecu tuning with a regrind and i/h/e?
          10whp from regrind... nice, ive been trying to find the number for the gain... what about the h23 manifold, what can be expected of that?
          Member Ride Facebook
          XBOX LIVE = RedDragonsFool
          SOLD MY CB JUNE 16, 2009
          For Sale Thread
