check engine light
    check engine light
    should the check engine light and battery and oil light come on with the key in the on position but not fired up.? it did on my old cb7... but it was fucked so i unno.
    i believe it should do it
    My Members Ride Thread
      My 92' LX sedan did that and my 91' EX coupe does that.... so i'm assuming that it's a yes.
      "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways-Jack Daniels in one hand-chocolate in the other-body thoroughly used up-totally worn out and screaming "WOO HOO!, What a Ride!
        ok so does anyone know the procedures to check ECU activity/ connections... or it even working... ? ? ? ? car wont start and its pissin me off... car only starts when i pour gas into the intake mani.
          Normal
          Yup..that's what it should do, then they should turn off once the engine's started
          Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
            Most of the lights should come on when your key is in the 2 (on) position. In the 1 position only the radio turns on. then 3 is start. On your passenger side there is a two pin connector jump it then turn your key to the on position or 2 then count the flashes.
              thx now i am trying to find out why my computer isnt going on.. there is 12 volts at both fuses and the fuses are good... im confused as to what is the problem.. the thermostat housing ground is intact... which ECU pins get grounded at the thermo housing.. maybe i got a cut wire somewhere if i can find out i can trace those grounds and run some new ones to the thermo if they are cut.. also what are the power sources for the ECU.. or is it multiple sources ... i dont get any info on this in my haynes book. also there is power going out FROM the ECU to the injectors so im realllllly fking confused... i double and tripple checked all my fuse box wiring and all the wiring to the ECU from the sensors etc.
              thx
                  not good
                    thx
                    u lost me...im trying to figure out why ur directly looking at the ecu...have ya done the basic stuff?? checked for spark..checked for fuel...checked for fuel IN the tank..im not trying to be an asshole...its just that i have seen people kick themselves in the ass in the end cuz they forgot or were just plainly too damn stubborn to check the simple stuff.......
                      yes i checked for all that. replaced the distrubutor, jump started the fuel pump because it was seized up and replaced the old fuel injectors. injectors have voltage and correct resistance, relay is activating the fuel pump. still no check engine light on the dash. problem must be in the wiring. car starts when i pour gas into the intake.
                      thx
                        well when you make the first trun with the key and the first click............. those light come on then go off when you turn on the car...............so thats a yes and if the lights stays on after the car is on well!...than you got a problem
                          X 2!
                          South Texas M_thaf_cka, that's where I stay!
                          Check out my Frost White CB
                          http://www.cb7tuner.com/vbb/showthre...ight=SpdJnky93
                            Yes guy thats normal. But only the battery and Oil light stays on.
                              thx
                              if you pour gas into the intake and it runs, that sounds like a fuel problem to me?
